Posted: 2020-05-27 08:46 AM
I have installed DCO 8.2.12 and the webmin interface version is 1.9 and the customer needs to upgrade the webmin to latest version cause he said that the webmin v1.9 has some security issues. So, is there a way to upgrade the webmin interface? and if i upgrade the DCO to the latest version, is the webmin will be upgraded too?
Posted: 2020-05-28 12:24 AM . Last Modified: 2020-05-28 12:29 AM
Hi Mohamed,
The latest updates, including Webmin version and OS/security updates would be in the latest release version(s) of ITA (currently 9.0.7). ITA is re-branding of DCO.
It is recommended that DCO in general should be upgraded to ITA. Following page:
https://helpcenter.ecostruxureit.com/hc/en-us/articles/360006367378-Upgrading-from-DCO-to-ITA
contains some details about moving from DCO to ITA, so it is recommended to be read before upgrading the product (DCO) to ITA.
Kind regards
Posted: 2020-05-27 11:27 AM
Hello Mohamed
Schneider does not directly provide updates to webmin, but you can use the webmin interface/menus to upgrade it.
When you login to webmin, the default page (system information) should show you a banner like this one below if an upgrade is available. You can click the "upgrade webmin now" button to update webmin.
Alternatively, you can use other webmin menu's to check manually.
Expand the Webmin menu, then Webmin Configuration, and click the "Upgrade Webmin" icon circled in red below.
In the "upgrade webmin" page you can ask webmin to check its website directly then click "upgrade webmin" to execute the upgrade.
Regards
Greg Sterling
Hi Mohamed,
Kind regards
