PDU firmware update unsuccessful
  • PDU firmware update unsuccessful
127
65
Posted: ‎2021-01-05 11:20 PM
3647
I am trying to do a firmware update to all my PDU's via DCE server.
9 out of m 152 PDU's were unsuccessful.
I get an "unable to connect" error although those PDU's are online and responding to PING.
PDU type is AP8886
The new firmware version is  6.9.6
Posted: ‎2021-01-06 12:53 AM . Last Modified: ‎2021-01-06 12:53 AM
3635
First you need to log in to the device via SSH or Serial and enable FTP using this command:
ftp -S enable
Next you need to download the files listed below from this link:
https://schneider-electric.box.com/s/v94kqtqgsb151rxljm47lp4bn5ajd89c
Connect to the NMC using FTP, I recommend the WinSCP client,
Upload "apc_hw05_bootmon_109.bin" to the root,
The NMC will reboot,
Reconnect via FTP,
Upload "apc_hw05_aos_696.bin" to the root,
Reconnect via FTP,
Upload "apc_hw05_rpdu2g_694.bin" to the root,
The NMC will reboot for the final time
-Gavan
Replies 4
3636
ftp -S enable
Reconnect via FTP,
Reconnect via FTP,
-Gavan
Posted: ‎2021-01-06 01:12 AM
In response to Anonymous user
Thanks!
I have enabled the FTP server and it's working now.
Posted: ‎2021-02-07 10:16 AM
3519
I'm trying this method via WinSCP, but the boot.bin file will not copy over to the nmc via FTP. It starts to copy and then the screen just disappears. I successfully connected via FTP. The NMC also shows that the AOS.bin file is already on there, but I am unable to delete that file. These latest updates are causing more trouble than anything. I have 334 APCs to update so one by one is not an option.
Posted: ‎2021-02-08 12:35 AM
Hi Willyhill,
These steps are only required if you are recovering from a failed update, otherwise you can still use DCE to do a bulk updated.
Also if you ready the steps above you will see that it will disconnect after you transfer each file and you don't delete anything.
-Gavan
