Posted: 2022-04-07 03:16 AM
HI there,
In my previous job I used Sysaid to monitor the estate PC's. I had hundreds of traps setup to notify me on a variety of different warnings, issues and failures. I also had a notification to let me know that whatever the notification was (warning, error, failure) I would receive a second notification to let me know that the device had recovered from what ever the issue was. That way I would know to ignore certain notifications as they are now resolved.
I'm trying to find in DCE a similar notification setting. When in Alarm Configuration Tab, right click all devices, Edit communication status thresholds - There's a Return to Normal Requires User Input. Would this enable a notification or have I got that muddled with another task?
Many thanks in advance, I'm sure there's a simple answer for this, just can't for the life of me find it.
Kind regards,
David.
Posted: 2022-04-19 06:29 AM
Hi David,
The setting "return to normal requires user input" is the opposite of what you're looking for - it prevents alarms clearing until a user acknowledges them - it intentionally stops alarms from going away on their own. This is useful for .. for example, if I have a Smoke Detection alarm - even if it clears, I should probably check it out.
The setting I believe you're looking for is actually in the email settings. So within a Notification Policy, when you add Send E-mail as an alarm action, the "Advanced Options" tab has a checkbox "Do not send Return to Normal messages".
The good news is the behaviour you're looking for is the default - but that's where the option lives so you can double-check it.
Shaun
