Posted: 2022-10-20 11:51 AM
unable to add netbotz 250 to DCE system.
when I add it as Netbotz type the system does not add it.
if I add it through SNMPV1 I have no problems.
If I add it as a Netbotz device, it does not register
Posted: 2022-10-20 11:40 PM
The Netbotz 250 is an NMC-based device. When you discover a Netbotz 250 in DCE, it should be discovered using SNMPv1 or v3 just like any APC Network Management Cards.
The only Netbotz devices that you need to discover as a Netbotz Appliance are the Netbotz v3 appliance. (NBRK0570, NBWL0455A, NBWL0355A, etc)
Hope this helps.
John
Hope this helps.
John
