Make change in (open LDAP/active directory bind setting)
  • Make change in (open LDAP/active directory bind setting)
129
72
kjvirgo2003
Crewman kjvirgo2003
Crewman
Posted: ‎2023-03-22 04:57 PM
1326
Can someone please help me, if I edit this (open LDAP/active directory bind setting)Is there any impact on the DCE or any services.?
Replies 4
ATrabert
Lt. Commander ATrabert Lt. Commander
Lt. Commander
Posted: ‎2023-03-23 05:43 AM
1314
Editing the authentication server bind setting does not cause DCE to reboot.  What are you editing?  Just the bind DN password?  Or are you changing the Bind DN user or authentication type from OpenLDAP to Active Directory?  Or Bind authentication type to use SSL?
Just editing the BindDN password shouldn't cause any issues.
However I've seen scenarios where changing the protocol doesn't take properly and will show that it's changed, but DCE is still using the old setting. In this scenario it is better to add a new authentication server, add your users/groups, then delete the old one.  Changing the bindDN user may also require removing/re-adding a new authentication server to DCE.
As always, make sure a local user account works before editing an authentication servers in DCE.
kjvirgo2003
Crewman kjvirgo2003
Crewman
Posted: ‎2023-03-24 03:28 AM
In response to ATrabert
Thanks, ATrabert for your Reply well Noted, we are going to change the DN user only.
so we have to remove the Authentication server and add it again?
ATrabert
Lt. Commander
Posted: ‎2023-03-24 05:21 AM
1279
You should be able to update the bind DN user without deleting/re-adding the authentication server.
kjvirgo2003
Crewman kjvirgo2003
Crewman
Posted: ‎2023-03-24 05:45 AM
ok ATrabert i will apply these setting and let you if there is any thing. thanks again .
