Send InviteCancel
Posted: 2022-06-1309:56 AM. Last Modified: 2025-04-0211:30 PM
Legend Settings and Plane Max/Min
In a recent update, we added Global Max and Min values reported right above the legend. We received some feedback that this could actually create more questions than answers when sharing the ITA CFD analysis results with customers.
To that end, we have added legend settings (found in the 'Settings' menu). This will allow you to switch the max and min values displayed above the legend to either
- 'Global' (the values that were displayed from the previous update),
- 'Plane' ( this is new and displays the max and min values of the visible field values plane)
- 'None' ('None' is the new default)
Also found in the legend settings are a pressure offset control and velocity vector components.
Note: The legend settings are available only those with the unlimited version of EcoStruxure IT Advisor CFD.
