Genoma Amphenol Network Solutions
  • EcoStruxure IT forum
  • Genoma Amphenol Network Solutions
126
65
Back to EcoStruxure IT forum
mgarciaMegacable
Ensign mgarciaMegacable
Ensign
Posted: ‎2022-09-05 09:07 AM
2195
I am looking for a genome for the "Amphenol Network Solutions" team, I was looking for one within the genomes but was unsuccessful, is there anyone who can help?
Amphenol Network Solutions > 60A DUAL-FEED COMPACT GMT FUSE PANEL (amphenol-ns.com)
  • Data Center Operation
Admiral
Posted: ‎2022-09-14 05:52 AM . Last Modified: ‎2022-09-14 05:53 AM
In response to mgarciaMegacable
2061
Hi Martin,
If I understand correctly you want to power your asset from a rack-ats and also from another source (rack pdu /rack ats), right? if yes, then that is not supported.
When we connect a rack mounted item/server with 2N redundancy, then it may/can be connected to 2 different power supplies (rack pdus) in the rack.
Rack ATS is usually is supplied by two different rack pdus, so therefore by design (due to power capacity calculations) a server can only be supplied from one inlet when connected to rack-ATS. That's also the notification being displayed for you:
Kind regards,
Replies 7
Admiral
Posted: ‎2022-09-06 12:32 AM
2170
Hi Martin,
Amphenol Network Solutions items not included in DCO/ITA Genome Library. You might want to submit a genome request here:
https://helpcenter.ecostruxureit.com/hc/en-us/requests/new?ticket_form_id=360000949677
As a current work-around you might use another network unit (from the Genome Library) and customize it in your Genomes to fit your need - eg. in Genomes you can modify the assets properties (Physical, Power and Network and other settings).
Kind regards,
mgarciaMegacable
Ensign
Posted: ‎2022-09-12 10:48 AM . Last Modified: ‎2022-09-12 11:01 AM
In response to Jef
2101
Hello @Jef
I need a genome that allows me to establish 2 power supplies (PDU1 and PDU2) and to be able to use this equipment as a power source for other equipment.
The problem I have is the following:
When selecting the source within the equipment it only allows me to select this equipment in only 1 power source and I need to set it in both; below a drawing.
I used the genome 1.4kW Single-Phase ATS / Metered PDU (PDUMH15AT) but was unsuccessful
Do you know any genome that can work for me?
Admiral
Posted: ‎2022-09-13 03:05 AM
2087
Hi Martin,
It doesn't seem to be genome related issue, but likely configuration related.
You can connect a server/asset (in 2N redundancy) to both rack pdus (assuming they have proper power configurations setup).
However, if you are connecting a server/asset to a rack ATS, then please note that server can be supplied only from one inlet when the rack ATS is used.
Kind regards,
mgarciaMegacable
Ensign
Posted: ‎2022-09-13 07:12 AM
In response to Jef
2078
Hello @Jef ,
Excuse me, I got confused, the configuration is with 2 supplies to 1 single dual supply.
I need a device that allows me to feed it from 2 power sources and other devices can be connected to this device, allowing 2N redundancy.
Admiral
2062
Hi Martin,
Kind regards,
mgarciaMegacable
Ensign
Posted: ‎2022-09-14 06:41 AM
In response to Jef
2055
@Jef
I understand, thank you very much
Admiral
Posted: ‎2022-09-14 07:01 AM
Hi Martin,
My pleasure & you are very welcome.
Kind regards,
