EcoStruxure Control Expert v 14.1 replace variables?
  • Industrial Automation
  • EcoStruxure Control Expert v 14.1 replace variables?
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
seichi
seichi
Cadet
Posted: ‎2022-04-25 10:54 PM
1269
Anyone know why "Replace Variables" is always greyed out for me in the Edit menu? I looked under options to see if that functionality needs to be enabled but didn't see anything. Not too familiar with this platform. Thanks in advance.
  • Tips and ideas
MatthewM
Lt. Commander MatthewM
Lt. Commander
Posted: ‎2024-07-31 08:36 PM
"Replace Variables" is for replacing variables within the scope of selected function blocks.  I.e, you have to select a function block(s) to give it a scope to search in.  You can select multiple blocks, but note that you can only select blocks, NOT connections.  If you select any connections, "Replace Variables" will again be unavailable.
It is also available by right clicking on a function.
You will then be able to enter a search and replace pattern, and it also has an option to create tags of the replacement will generate tags that are not yet defined.
