Posted: 2022-07-22 08:46 AM . Last Modified: 2022-10-19 12:45 AM
Referring to the known issues : https://dcimsupport.ecostruxureit.com/hc/en-us/articles/360010560018
and also this post: https://community.se.com/t5/EcoStruxure-IT-forum/No-return-to-normal-emails-after-upgrade-to-DCE-7-9...
If I have deployed at 7.9.0.193 does updating to 7.9.1 remove the issues seen in the versions 7.9.0.192/193/194?
Regards
Posted: 2022-07-22 09:51 AM
Hi Gary,
DCE 7.9.0.196 addresses the issues seen in prior releases of DCE 7.9.0.
Here's the complete list of known issues: https://dcimsupport.ecostruxureit.com/hc/en-us/articles/360010560018-Known-issues-in-DCE
Best,
Jackie
Posted: 2022-07-27 01:30 AM
Thanks for the answer, however it was not quite the answer to the question 😉
I have a deployment on 7.9.0.193 that took 14 hours to backup from 7.8.1 then a similar time to restore to 7.9.0.193.
I don't want to have to rebuild and restore this DCE again given the amount of data (and time) involved. So my hope was that updating to 7.9.1 would resolve the issue in 7.9.0.193.
As I understand the other alternative is to allow SE remote access to the DCE (I assume via SSH) which this customer is unlikely to permit.
As a SE partner can we be given the instructions on how to do what is required?
Regards
