Data Center Expert - How to Extract Compressed Backup File
  • Data Center Expert - How to Extract Compressed Backup File
129
72
MateFekete
Ensign MateFekete
Ensign
Posted: ‎2023-01-19 07:34 AM
1104
I have a full type backup file from DCE 7.8.1 which is compressed (one file with *.dce extension).
Due to migration to 7.9.0 I wanted to restore that backup but it failed after about 4 hours with following error: "Failed to extract".
Is there any way to manually extract that "dce" file extension and restore that?
Shaun
Commander Shaun Commander
Commander
Posted: ‎2023-01-19 08:29 AM
If you rename the file from .dce to .tar.gz it should extract with many archive applications.
In order to restore from this backup, ensure that it's extracted into a folder with the same name as the .dce file had.  eg, if you have backup_hostname_timestamp_version.dce, you should have extracted backup_hostname_timestamp_version/backup.properties etc (This path isn't stored in the archive file).
Shaun
Commander
