DCE stuck after reset: server is currently starting up.
  • DCE stuck after reset: server is currently starting up.
129
112
72
MantasMik
MantasMik
Cadet
Posted: ‎2023-11-22 03:07 AM
1
894
DCE 8.0.0 stuck all the time after server reset and shows error (attached).  going into details you can find indication with SQL error (attached). And from this point the only way to fix that is to create new VM. Once you do the reset, the same issue appears. Needs help in solving that.
JohnBT
Lieutenant JG JohnBT Lieutenant JG
Lieutenant JG
Posted: ‎2023-11-26 10:58 PM
Database error is mostly related to storage.  Did you add a second HDD to the DCE VM? Increasing the initial storage will not work.  Try adding an additional HDD and see if that works.
If you have a full backup, you can deploy a new DCE. Just make sure to add a second HDD.
If this is not an option for now, you can contact your local technical support, check the link below and change the Country.  Provide the DCE logs.  Go to https://dce_ip/capturelogs and create a new server log archive.
https://www.apc.com/au/en/support/
