DCE CSR request
  • DCE CSR request
129
72
silvia_scv
Crewman silvia_scv
Crewman
Posted: ‎2022-09-15 01:59 AM
2
1107
DCE CSR request
I'm trying to obtain an SSL certificate for our DCE server. I created the CSR as described below:
Once I get the string to be decoded I get the error here below on the left:
Could you please help me understand what the issue is?
Thank you
Silvia
ATrabert
Lt. Commander ATrabert Lt. Commander
Lt. Commander
Posted: ‎2022-09-22 06:38 AM
1053
which version of DCE are you running?  Do you have an a FQDN in your Common name CN  field, eg DCE.mydomain.com?  DCE uses the CN in the SAN field, so the only reason I could think this would happen is if you are using 127.0.0.1 in the CN field.  If you were trying to generate a signed SSL cert, it should contain a valid FQDN.
As the directions state, if you are not running the latest version of DCE, 7.8 or 7.9, it is also recommended that you upgrade to one of these versions.  This will require an active support contract.
silvia_scv
Crewman silvia_scv
Crewman
Posted: ‎2022-09-22 07:04 AM
In response to ATrabert
Hi Andrew,
I'm running DCE 7.8.1 and in CN there is the hostname (FQDN) of our DCE server, that's why I am confused by the error. I tried to rewrite it just in case but the issues remains.
