Posted: 2023-04-18 04:22 AM
Dear support,
I have encountered that after upgrading the DCE-7.9.1 to DCE-7.9.2/7.9.3, the UPS Total Output Active Power (Watts) sensors are no longer available (Unplugged). An analysis of the changes to the SNMP DDF file apcsmartups.xml v.129 indicated that since DCE-7.9.2:
The following have been moved to a supplementary DDF (apcsmartups_watts_from_va.xml):
We have chosen to remove these sensors as they have been reported by customers to provide
inaccurate/misleading data. If a customer requests to see the per-phase output power in watts
and it is not supported by the device, they can add apcsmartups_watts_from_va.xml DDF to DCE
in addition to apcsmartups.xml DDF
It's strange that there is no mention of this important change in the release for DCE-7.9.2 or DCE-7.9.3. Furthermore, I could not find the mentioned new SNMP DDF file apcsmartups_watts_from_va.xml on https://ddf.ecostruxureit.com/ (only apcsmartups.xml, for example).
Please help in solving this problem, in the meantime, the solution is to revert to using the SNMP DDF file apcsmartups.xml v.123 from DCE-7.9.1
Very thanks for the support.
Posted: 2023-04-24 06:22 AM
Hello Spezialist. We apologize for the delay. Attached is the DDF you are looking for. We will make sure to address the underlying issues you've highlighted.
Posted: 2023-04-22 07:03 AM
Dear support, where can I download the SNMP DDF file apcsmartups_watts_from_va.xml?
Posted: 2023-04-24 09:26 AM
Dear @mwhelihan,
Great -- that's what's needed. Recently checked this new SNMP DDF-file on two different DCE-7.9.3 servers: the result is positive, UPS Total Output Active Power (Watts) sensors are back.
