DCE 8.3.0 - Domain name won't change nder Network Settings
Select a Country
  • DCE 8.3.0 - Domain name won't change nder Network Settings
Cory_McDonald Champion
160
Jef Leader
114
gsterling Mentor
77
Jennifer
Jennifer Explorer
Explorer
Posted: ‎2025-10-01 07:46 AM
3
1864
I'm running EcoStruxure Data Center Expert 8.3.0 as  VM in VMware for a lab. I'm trying to change the Domain Name in System>Server Admin Setting>Network Settings to dce.local. The change appears to save but does not persist after reboot and reverts and no changes happen.
Thanks in advance - please advise the supported procedure or any known fixes for 8.3.0.
Jenn
APC_Steve Leader
Leader
Posted: ‎2025-10-01 10:17 AM
Hi @Jennifer ,
I thought I had seen something similar some time ago but thought it had been addressed. I will look into that in a little more detail but in the meantime, I would suggest changing the hostname using the console and the apcsetup user.
Steve
ATrabert
ATrabert Mentor
Mentor
Posted: ‎2025-10-02 12:03 PM . Last Modified: ‎2025-10-02 12:03 PM
in general, .local shouldn't be used since it's used by mDNS https://datatracker.ietf.org/doc/html/rfc6762 and if you check your DCE nbc.xml log, you'll see an error regarding it
10/2/25 14:44:13.360 WARN - Handler execution resulted in exception
(com.netbotz.server.services.serveradmin.controllers.SetNetworkSettingsController)
java.lang.IllegalArgumentException: invalid dns domain at com.netbotz.server.services.serveradmin.controllers.SetNetworkSettingsController.validateDnsSettings(SetNetworkSettingsController.java:123)
like Steve mentioned, you can get around this by using it with the apcsetup console script.  I've also logged a ticket with our development team about it
ATrabert
ATrabert Mentor
Mentor
Posted: ‎2025-10-15 06:53 AM
setting the DCE domain to .local and .localdomain via the desktop client will be fixed in the next DCE release, 9.1
