Requirements for EcoStruxure IT Expert API
See how to access the EcoStruxure IT Expert API to integrate EcoStruxure IT into your environment. A valid IT Expert subscription is required.
Send InviteCancel
A valid IT Expert subscription is required to use the EcoStruxure IT Expert API. Partners can use the API for their customers if that customer has an IT Expert subscription.
Customers and Partners using the API should make sure that the calls they make don't cause performance issues for the EcoStruxure IT platform or for other API users.
Schneider Electric reserves the right to disconnect customers or Partners either temporarily or permanently if their API calls cause performance issues.
