Connect with IT Design CFD software users to optimize data center equipment layout, cooling, and energy consumption using computational fluid dynamics (CFD).
Send InviteCancel
Send New InviteClose
Posted: 2022-02-1401:53 PM
Monitor Regions
ITA CFD now supports monitor regions.
Monitor regions are user defined volumes that will report Min/Max/Avg of Temperature, Pressure, and Speed for the volume. The data is available on the tooltip hover over, once an analysis has been run.
A monitor region can be placed just like any other piece of equipment.
They can be adjusted down to the size of a single cell or increased to the size of the entire room.
In the attached screenshot, the monitor region is being used to examine the airflow coming out of the four perforated floor tiles closest to the cooler.
Containment also now reports the same information that the monitor regions do in the hover over tooltip.
If you have questions, send us an email (CFD_support@se.com) or ask here!
