What does "object orientation" mean and what are its benefits?
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • What does "object orientation" mean and what are its benefits?
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
EcoStruxure™ Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
Rodrigo_Garcia
Commander Rodrigo_Garcia Commander
Commander
Posted: ‎2020-09-15 08:39 AM . Last Modified: ‎2023-07-28 02:26 AM
1663
Rodrigo G.
Industrial Automation Community manager
  • faq
  • IEC 61499
Posted: ‎2020-09-16 01:53 AM . Last Modified: ‎2020-10-02 02:46 AM
Object orientation refers to the holistic view of automation components or functions. A component (e.g. an engine or an entire air conditioning system) is represented as a software object that combines several of its technological aspects: control logic, visual representation, process connection (I / O), documentation and others. Such an object is essentially independent of hardware and can therefore be reused without restrictions. The object type instance model has the advantage that a change to the object type is automatically passed on to all instances of this type if desired.
The main benefits are:
  • Engineering efficiency - building applications bottom-up with well-structured object libraries results in a highly efficient engineering process
  • Higher quality - the use of proven-in-use objects results in much higher quality - with quicker testing and reduced time spent on bug-fixing
  • And a as result a much quicker time to market.
You can learn more about engineering efficiency in the white paper here: https://www.se.com/ww/en/download/document/998-21022781/
And for more information on IEC 61499, download the whitepaper "IEC 61499: The Industrial Automation Standard for Portability that Unleashes Industry 4.0".
