Un error Edge IO NTS
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
Send InviteCancel
Posted: 2025-11-1008:03 PM
We have a Schneider kit that includes the essential edge controller, the Harmony BX1, which is connected to a network interface called the Modicon Edge I/O NTS. This setup has both digital input and analog input modules. However, we are experiencing an issue with the Edge I/O NTS; the RUN LED is off, while the ERR LED is flashing. Additionally, both the NS and MS LEDs are flashing green. What is the problem?
