The "NIC_1\Ethernet Interface\IP Address" used for "Runtime_1\Deployment" is maybe not reachable from local station?
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • The "NIC_1\Ethernet Interface\IP Address" used for "Runtime_1\Deployment" is maybe not reachable from local station?
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
EcoStruxure™ Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
Gintoki
Crewman Gintoki Crewman
Crewman
Posted: ‎2021-10-27 02:35 AM . Last Modified: ‎2023-07-28 02:24 AM
1239
Hi, i am relatively new to EAE and SCD6000 and am currently working with EAE and SCD60000.I have a SCD6000 soft dpac device configured in Ecostruxure Automation expert. The SCD6000 and Operating PC ae connected via ethernet and the connection is running good and the corresponding IP address is configured into soft dpac workstation in EAE too. But i am still not able to login to the device from EAE. what might be the possible reasons for this error?
Thanks in advance!
Edit :
I am able to login now, it was a error with the config file, protocol related format declaration.😅
TomRos
TomRos Schneider Alumni (Retired)
Posted: ‎2021-10-27 06:57 AM
1223
Thanks for the update @Gintoki, please don't hesitate if you have any additional questions!
Gintoki
Crewman
Posted: ‎2021-10-27 08:40 AM
In response to TomRos
Yeah, i definitely will. Thank you!😁
