SCHNEIDER M241 init_error while logging data
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • SCHNEIDER M241 init_error while logging data
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
Logic Controller - Modicon M241
Back to EcoStruxure Automation Expert / IEC 61499 Forum
dimmitrisd
Crewman dimmitrisd
Crewman
Posted: ‎2024-07-02 11:13 PM
I get the following "init_error" when the controller tries to write the log file.
The file is already created as the PLC was running successfully, but this sometimes happens when I edit the code that was already running for a long period and make some changes and while downloading many times the new project, then this problem may I appear.
I've tried stopping the PLC and deleting the files in the log folder. The problem remains.
The only solution that works always for me when this happens,  is to make a full restart of the PLC by powering off the main power and then again back on. This way the problem disappears and everything works again.
Replies 0
