Runtime Application Initialisation
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • Runtime Application Initialisation
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
Back to EcoStruxure Automation Expert / IEC 61499 Forum
chiborjay
Ensign chiborjay
Ensign
Posted: ‎2025-02-26 06:20 AM
3054
Hi, I'm a newbie to automation in general and currently practising with EAE. I'm using a test rig - Conveyor sorting line with colour detection. My challenge is that I'm unable to write in fields to ascertain better operation and precision of pistons for sorting the colour blocks. The conveyor starts running when there's an object before the entry sensor but the compressor doesn't activate which doesn't energise the solenoid pistons in return. Please see attached photos for the fields requiring "write" and also the error message from the Local HMI connection. Happy to answer further questions regarding the issue. ThanksScreenshot 2025-02-26 135240.pngScreenshot 2025-02-26 135352.png
  • Portability-Interoperability-Configurability
mohamedriswan
Ensign
Posted: ‎2025-02-27 08:51 PM
3007
Hi Chiborjay,
Could you check in your IThis block whether the INIT request is connected? Additionally, can you verify if the DPAC_FULL_INT resource blocks are initialized? Attached the initialization snaps for your reference.
theo.bagieu
Ensign theo.bagieu Ensign
Ensign
Posted: ‎2025-02-28 01:20 AM . Last Modified: ‎2025-02-28 01:21 AM
In response to chiborjay
2995
  • Your pictures have been well received now, thanks.
    Based on @mohamedriswan comment, you will need to look that your application initialization sequence is fully completed :
  •  You have a DPAC_FULLINIT block in your app (it look like you had one)
  •  All the block that required initialization are correctly linked in serie ( INITO to next INIT ), avoid parallel event chain here. Double check especially for your iThis block inside your CAT too.
  • All the QI data input are TRUE when the INIT event arrived.
    Also, do you use any plcStart block within your application?
    Let us now if it's fixed or not, and don't forget to mark a response as solution if it's okay.
Replies 20
theo.bagieu
Ensign
Posted: ‎2025-02-27 12:03 AM
3045
I think there is an issue with the picture you've shared as i don't see them.
Can you try uploading them again please ?
chiborjay
Ensign chiborjay
Ensign
Posted: ‎2025-02-27 12:25 AM
In response to theo.bagieu
Hi Theo, yes sure. ThanksScreenshot 2025-02-26 135352.pngScreenshot 2025-02-26 135240.png
chiborjay
Ensign chiborjay
Ensign
Posted: ‎2025-02-27 12:29 AM
Hi, I've just replied and uploaded the photos again. For some reasons, I can't see my reply in the thread. Please let me know if you see it. Thank you
chiborjay
Ensign chiborjay
Ensign
Posted: ‎2025-02-27 03:39 AM
Here's the photos uploaded again
chiborjay
Ensign chiborjay
Ensign
Posted: ‎2025-02-27 03:42 AM
Hi, I've now just replied to the topic and uploaded same photos. Kindly check if you see it there.
Thanks very much
chiborjay
Ensign chiborjay
Ensign
Posted: ‎2025-02-27 03:54 AM
3021
Screenshots.zip
mohamedriswan
Ensign
3008
Hi Chiborjay,
chiborjay
Ensign chiborjay
Ensign
Posted: ‎2025-02-28 12:32 AM
In response to mohamedriswan
Hi Mohamedriswan, thank you for your help.
Here's a screenshot of my block connections. The INIT request is definitely connected.
theo.bagieu
Ensign
2996
chiborjay
Ensign chiborjay
Ensign
Posted: ‎2025-02-28 01:58 AM
Hi Theo, I believe the blocks in my program is set up as you have described. See attached screenshot. Thanks
theo.bagieu
Ensign
Posted: ‎2025-02-28 02:14 AM
2986
@chiborjay
Glad to know that your issue is solved.
Can you give us more information about how you resolved your issue ? It could be usefull for any other peoples having the same issue 😊
However, it look like we do have issue to see your screenshots. You can use the camera icon in the message bar to post your picture.
chiborjay
Ensign chiborjay
Ensign
Posted: ‎2025-02-28 02:25 AM
2984
Hi @theo.bagieu the issue hasn't actually been resolved entirely. I'd marked the suggestions from yourself and @mohamedriswan as solutions when you said "not to forget to mark a response as solution" in your previous comment. The persisting issue here is that when I try to run the program, it doesn't particularly work as expected and "write" on the HMI is not working and I need the "write" for some sort of tuning. When I check the connection on the Local HMI runtime, it says "Runtime Application is not initialised/Partially Initialised". I believe this to be the reason why "write" field on the HMI doesn't work.
theo.bagieu
Ensign
Posted: ‎2025-02-28 02:45 AM
2981
What about the initialization checks that @mohamedriswan & I mentioned?
chiborjay
Ensign chiborjay
Ensign
Posted: ‎2025-03-03 12:12 AM
Hi @theo.bagieu I'm not sure why you can't see my uploaded pictures. I believe the initialisation have been done and connections INITO of the DPAC_FULLINIT to INIT of the conveyor. I'll attach a screenshot here, see if you get it please. ThanksScreenshot 2025-02-28 082156.png
chiborjay
Ensign chiborjay
Ensign
Posted: ‎2025-03-03 06:32 AM
2871
Screenshot 2025-02-28 082156.zip
theo.bagieu
Ensign
Posted: ‎2025-03-04 12:07 AM
Hi @chiborjay
Can you please send me an archive of your project to look at it ?
To do that, in EAE go to "Files>Archive". Please include all the libraries.
Then you can send it to me using direct messages :
Hover my profile, then Direct Messages.
If the file is too big, please use another file transfer tool of your choice.
theo.bagieu
Ensign
Posted: ‎2025-03-04 06:01 AM . Last Modified: ‎2025-03-04 06:01 AM
2784
Hi @chiborjay
I successfully received your application.
It look like your initialization chain is not good inside your blocks.
Can you please review for all your blocks the following point I've mentionned in my previous messages :
    While checking your application, the INIT are mostly wired in parallel, some aren't wired, and many QI inputs are not set.
    Also, you've used plcStart FBs, in addition of an INIT input in your CAT. You can rely on only one unique INIT chain in your case. As soon as you use the plcStart, you should wire the end of your INIT chain (ie. last INITO) to the ACK_FIRST of the plcStart block.
    (i've blured your custom blocks for privacy)
    Can you check all of this for each of your blocks and try again please ?
chiborjay
Ensign chiborjay
Ensign
Posted: ‎2025-03-04 06:19 AM
Hi @theo.bagieu  thanks. I'll have a look through again now. Much appreciated
chiborjay
Ensign chiborjay
Ensign
Posted: ‎2025-03-04 06:45 AM
@theo.bagieu I've tried having a look there and was going to send you a direct message but the button's no longer there on your profile. Anyway, the bigger issue now is that the blocks are pre-made ones by Schneider and locked, can't edit them at all. Guess there's not much that can be done in this case eh?
chiborjay
Ensign chiborjay
Ensign
Posted: ‎2025-03-04 07:04 AM
Please ignore the last comment about the blocks being locked.
