Passing DI signal to DO signal within EAE
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • Passing DI signal to DO signal within EAE
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
Back to EcoStruxure Automation Expert / IEC 61499 Forum
Eyanto
Ensign Eyanto
Ensign
Posted: ‎2025-08-20 09:23 PM
628
Hi All,
Still new in EAE and hope to get some helps from the community.
We have configured the application to symlink Modicon STB into EAE which consists of DI and DO signals.
We managed to get the DI signal from Modicon STB using DisplayBool FB and also managed to trigger the DO signal to Modicon STB using SetBool FB as shown by below pictures.
Now, we are required configure inter-link logic between the DI and DO. However, there is only single connection point from both FBs. Kindly guide us. Thanks
Eyanto
Ensign Eyanto
Ensign
Posted: ‎2025-09-02 09:13 PM
In response to theo.bagieu
Hi @theo.bagieu, thank you for following up.
Yes, we managed to solve the issue with help from SE Malaysia support as well.
Utilizing Island_Word2Bit FB, split the output to DisplayBool and N1 FBs. N1 FB acts as OR gate receiving the signal from sensor 1 or 2 to trigger the output. In the same time, it can also receive manual input from SetBool FB for Lamp Test function. Below are the logic snapshots.
Thank you again for your recommendations. 
Replies 5
theo.bagieu
Ensign theo.bagieu Ensign
Ensign
Posted: ‎2025-08-25 12:38 AM . Last Modified: ‎2025-08-25 12:39 AM
598
Hi @Eyanto
I will assume that your request is not only to link DI to the DO but you want to keep your HMI SetBool and DisplayBool Logic.
I will consider 3 major solutions there, depending on your needs :
  • Create your own CAT, with custom logic to Display/Set your bool(s) either from the application or the HMI, but you will have to manage yourself bypassing, forcing control etc etc.
  • Kept the SetBool & DisplayBool and use a DS_SELECTX block. This FB helps you to select between two data depending on which event input is triggered. In your use case, your HMI could be on REQ1/DI1_1 and your loopback from the IO on the REQ2/DI2_1.
  • If you wish to had a advanced & complete I/O control, you can use the FB from the AppCommonProcess or App2CommonProcess like DigitalInput & DigitalOutputtheobagieu_1-1756107461708.png
    These will have a complete HMI support, alarm management, and process library integration.
    Hope it helps
Eyanto
Ensign Eyanto
Ensign
Posted: ‎2025-08-26 06:02 PM
570
Hi @theo.bagieu ,
Your assumption is correct. We would like to retain the SetBool and Display Bool FBs while creating another interlink DI and DO.
Besides that, thank you for you suggestions. We will try them out.
theo.bagieu
Ensign
Posted: ‎2025-09-02 01:53 AM
In response to Eyanto
543
@Eyanto is your issue solved ?
Eyanto
Ensign Eyanto
Ensign
nawawiid
nawawiid
Cadet
Posted: ‎2025-09-17 02:04 AM
Hi @theo.bagieu
Regarding on your solution for Yanto
I already try this method, but DO output value not trigger (passing)
thanks in advance Mr.Theo
