Is real time possible with IEC 61499?
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • Is real time possible with IEC 61499?
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
EcoStruxure™ Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
Rodrigo_Garcia
Commander Rodrigo_Garcia Commander
Commander
Posted: ‎2020-09-15 08:35 AM . Last Modified: ‎2023-07-28 02:26 AM
3
3345
Rodrigo G.
Industrial Automation Community manager
  • faq
  • IEC 61499
Posted: ‎2020-09-16 12:58 AM
Our measurements with EcoStruxure Automation Expert show that event-driven systems are extremely efficient in terms of resource use, more so than scan-based systems. We are currently running field tests with industrial customers for different applications. Please contact your Schneider Electric Representative to learn more.
RakeshSuresh
Crewman RakeshSuresh Crewman
Crewman
Posted: ‎2021-05-20 08:21 AM
1
3040
There is a possibility to enable Real-time in IEC61499 using  E_CYCLE Function Block, which can be used as the clock generator.
Bram-Marsman
Crewman Bram-Marsman Crewman
Crewman
Posted: ‎2021-09-07 11:33 PM
In response to RakeshSuresh
The term "real-time" is confused here with cyclic I think.
A more accurate description would be that E_CYCLE allows you to do classic cyclic control, which is not the intent off course.
However, don't forget cyclic control will always be required.
For time-related computation, such as PID-control or accumulators you will need E_CYCLE even - or I should say especially - when nothing changes / no event occur.
