Inquiry About Using CRA31210 Service Port for Modbus Device Connection
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
Send InviteCancel
Posted: 2025-08-0908:09 AM. Last Modified: 2025-08-0908:10 AM
Hi Everyone,
I would like to confirm whether the service port on the Modicon RIO Drop CRA31210 can be used to connect directly to an external Modbus TCP device for data exchange.
My understanding is that the service port is primarily intended for engineering and maintenance purposes, but I would like to verify if it can also function as a communication channel for Modbus TCP between the RIO drop and third-party devices.
If supported, could you please provide any relevant configuration guidelines or documentation? If not, could you suggest an alternative approach for achieving this type of connection?
