Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
Posted: 2023-03-10 05:29 AM . Last Modified: 2023-07-28 02:21 AM
I am inserting a new Modbus TCP device and adding a request of RD adress = 1000 and Length = 4
In the Variables List I am getting a corresponding Inputs Free0 array [0..3] of BYTE.
How can I change that to an Inputs Free0 array [0..1] of INT?
Posted: 2023-03-10 08:39 AM
In Request Items, press on define, select your BYTEs to redefine them in INT and ARRAY like this:
After the redefinition, you obtain this:
Posted: 2023-03-10 06:00 AM
Your screenshot are from Control Expert, not EAE ;-).
To answer, in the CE DTM select your 4 bytes to redefine them (manually) in Array of 2 words (or INT).
Regards
Seb
Posted: 2023-03-10 07:46 AM
Thanks for the reply.
Note that the variable has the lock symbol.
I tried a double click on the Type field, but I do get the dropdown to select the Type nor it does allow me to write anything in there.
Posted: 2023-03-10 10:07 AM
Thanks a lot..much appreciated
