How to import graphical nuget packages
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • How to import graphical nuget packages
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
Back to EcoStruxure Automation Expert / IEC 61499 Forum
chrisholl13
chrisholl13
Cadet
Posted: ‎2023-10-20 01:14 AM
886
I would like to import a nuget package into EAE for a gauge graphic as I cannot see one that matches what I want in the current libraries. How do I go about installing on of these packages so I can use them in the HMI?
  • Asset-centric (CAT + Objects)
DP-JYC
Lieutenant JG DP-JYC
Lieutenant JG
Posted: ‎2023-10-22 04:50 AM
Correct, I'm also no aware of installing directly NuGet packages in EcoStruxure Automation Expert (EAE). You'll need to install the NuGet package on your development machine, extract the relevant DLL files, and then import those into EAE to use in the HMI.
  1. Install the NuGet package using NuGet Package Manager or nuget.exe.
  2. Navigate to the packages directory to locate the DLL files.
  3. Copy the required DLLs.
  4. Import the DLLs into your EAE project.
And voilà! You've turned EAE into a DLL sommelier, choosing only the finest libraries for your HMI ☺️
