How import Alarms from Excel
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
Showing results forΒ
Did you mean:Β
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • How import Alarms from Excel
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
EcoStruxureβ„’ Operator Terminal Expert 3.1
EcoStruxureβ„’ Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
rodolfo_costa
Crewman rodolfo_costa
Crewman
Posted: β€Ž2023-03-09 04:10 AM . Last Modified: β€Ž2023-07-28 02:21 AM
6
3242
I'm currently developing a project where I can handle 700 alarms on a console and from what I understand I have to introduce all the alarms one by one. I would like to know if there is any way to import them, for example through an excel or something similar.
I'm working on operator terminal version 3.3
Can anyone help me?
  • faq
rodolfo_costa
Crewman
Posted: β€Ž2023-03-17 02:05 AM . Last Modified: β€Ž2023-03-17 02:06 AM
In response to samatcha
3214
I contacted Schneider support and what I was told is that it is necessary to create 2/3 alarms, then export the console variables and within excel it is possible to create the alarms with the respective message and later import
See if it works
Replies 6
samatcha
Crewman samatcha
Crewman
Posted: β€Ž2023-03-17 01:57 AM
3224
Same issue here. Such a painful working with alarms.
rodolfo_costa
Crewman
3215
See if it works
DP-JYC
Lieutenant JG DP-JYC
Lieutenant JG
Posted: β€Ž2023-03-17 02:06 AM
Sorry to read that your experience is not optimal.
Unfortunately, here, we are not so much knowledgeable about "operator terminal version 3.3" as it's a forum about "EcoStruxure Automation Expert". (where BTW, working with alarms is great as everything is an Object, and you have objects in objects in objects πŸ˜‰)
samatcha
Crewman samatcha
Crewman
Posted: β€Ž2023-03-17 05:10 AM
In response to rodolfo_costa
3201
Could you please give me more detail what do you mean by 2/3 alarms?
I have no idea how to export and import alarms would you mind explain it to me?
rodolfo_costa
Crewman
Posted: β€Ž2023-03-17 06:59 AM
1
3196
After creating these alarms, it is necessary to go to the variables and export them to excel. After that, it's only necessary to manipulate the rest of the variables you want as an alarm, just like the ones you just created.
When saving the file you want to import, I advise you to choose the following: .txt(ms-dos)
samatcha
Crewman samatcha
Crewman
Posted: β€Ž2023-03-17 03:10 PM
I'm got it. Thank you very much.
Β
