How complex is it to customize the EcoStruxure Automation Expert libraries?
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • How complex is it to customize the EcoStruxure Automation Expert libraries?
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
EcoStruxure™ Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
Rodrigo_Garcia
Commander Rodrigo_Garcia Commander
Commander
Posted: ‎2020-09-15 09:08 AM . Last Modified: ‎2023-07-28 02:25 AM
2682
Rodrigo G.
Industrial Automation Community manager
  • faq
JeromePetit
Ensign JeromePetit Ensign
Ensign
Posted: ‎2020-10-02 12:55 AM
Once you have been trained on EcoStruxure Automation Expert, it is very straightforward to create your own libraries.
You can do your library from scratch or you can extend and adapt existing objects from the libraries to create composite blocks that will fulfill your requirements.
In addition, any change to a "type" is automatically forwarded to all the instances project.
JeromePetit
Ensign
