EAE Event counter details
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • EAE Event counter details
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
EcoStruxure™ Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
anandbpillai
Ensign anandbpillai Ensign
Ensign
Posted: ‎2022-04-19 12:29 AM . Last Modified: ‎2023-07-28 02:23 AM
3332
For the EAE Events generated for any Function Block, what is the maximum capacity of this event counter.
And what happens when it reaches its max. capacity.
Also what kind of data type int, long, double etc.
DP-JYC
Lieutenant JG DP-JYC
Lieutenant JG
Posted: ‎2022-04-20 12:49 AM
In response to anandbpillai
I don't know what's the maximum value and as it's an informative number of event count, you can't get this number in the application. Yes, it reset automatically, you don't need to take care of this.
If you want to count the number of events in your application, you need to handle a "Data Pin" with your own logic.
Event Blocker is useful to debug your application, but not in production!
If you need Event Blocker in prod, I would say that It most probably means that you have a design issue!
DP-JYC
Lieutenant JG
Posted: ‎2022-04-19 12:33 AM
3329
This value is only an indication (very useful when you debug).
You can even reset it with a right-click.
So it will restart counting arriving at the "max" (whatever this max is)
anandbpillai
Ensign
Posted: ‎2022-04-20 12:37 AM
In response to DP-JYC
3289
Thanks for the update.
But if don't reset manually does it automatically reset, if yes than after which value.
Also we have seen that we need to use Event Blocker in some application after FB's to help restrict continuous event generation in the EAE application.
Is it right way or best practice in EAE application configuration.
DP-JYC
Lieutenant JG
