Connect to device (M251d)
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • Connect to device (M251d)
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
EcoStruxure™ Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
Posted: ‎2022-05-10 01:50 AM . Last Modified: ‎2023-07-28 02:23 AM
3
3667
I would like to connect to my M251d, following the instructions on the documentation with the login installer / *********, but the PLC is always rejecting the connection.
Check the picture below:
Is there a way to do a factory reset ?
Thank you.
Santhosh-PB
Crewman Santhosh-PB Crewman
Crewman
Posted: ‎2022-05-10 03:59 AM
2
3649
Hi
from the snap the M251d is already configured using another solution and hence the default credentials is no more valid.
if you donot remember the credentials, only way is to reset the device. Please refer to the M251d user manual installed with SW.
Refer to the below chapter on how to use SD Card to reset device.
Santhosh-PB
Crewman
2
3650
Hi
Posted: ‎2022-05-11 12:47 AM
In response to Santhosh-PB
Thank you !
JacobJ
Crewman JacobJ
Crewman
Posted: ‎2022-08-17 04:13 AM
Thanks for sharing such a helpful instruction.
