Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
Posted: 2021-12-01 09:29 AM . Last Modified: 2023-07-28 02:23 AM
I am trying to figure out how I can alternate between a set of images based on an integer value used as an Interface input pin.
For instance I would like a value of 1 select image 1. value of 2 select image 2, etc.
The interface pin graphical object that are pre-defined do not seem to have any image options.
Likewise the standard rectangle that I can attach an image to, has no way to link a tag from the Interface.
In Vijeo Designer this would be quite easy using visibility parameters.
How do I accomplish something like this in Automation Expert?
Posted: 2021-12-01 10:08 AM
Hi
Just use Image primitive
Use the Ranges property to define the enum with selected images
Br,
Gernot
Hi
Br,
Gernot
Posted: 2021-12-01 10:25 AM . Last Modified: 2021-12-01 10:26 AM
Thank you. I am embarrassed, as I had my integer on the output by accident, which does not have the same selections as an input does.
Posted: 2021-12-01 10:51 AM
Wow, nice tips @GKollegger
I would have code it the "hard" way with n rectangles and play with the visibility in the C# part in execute function of the value.
But EAE gets you a lot of useful primitives, I should use them more often.
Thx for sharing.
