CPU load spike analysis
EcoStruxure Automation Expert / IEC 61499 Forum
Schneider Electric support forum to acquire and share knowledge about EcoStruxure Automation Expert and IEC 61499 standard for distributed control systems.
  • Industrial Automation
  • EcoStruxure Automation Expert / IEC 61499 Forum
  • CPU load spike analysis
mohamedriswan
Ensign mohamedriswan Ensign
6
KarimBenameur
Ensign KarimBenameur Ensign
4
EcoStruxure™ Automation Expert
Back to EcoStruxure Automation Expert / IEC 61499 Forum
anandbpillai
Ensign anandbpillai Ensign
Ensign
Posted: ‎2023-01-04 02:23 AM . Last Modified: ‎2023-07-28 02:22 AM
1204
Hi team,
We are conducting the performance test (using MIBGET block) on the application on below EVE setup details.
Soft dPAC with Archive database
Local Test simulation
Version 22.0
In the attached report, we are getting many peaks in CPU Load as seen in the report. We want to know proper reason for this spikes by using some details so that we can improve them or How to identify these spike reasons in EAE.
Pls suggest.
KarimBenameur
Ensign
Posted: ‎2023-01-04 02:34 AM
1200
Hi anandbpillai,
can you provide your application so we can reproduce ? On which IPC are you running (CPU/Ram) ? which Linux Distro ? do you have a Real Time patch applied ? if not can you redo the test with a patch ?
It is difficult to know why you have this spike without further investigation.
anandbpillai
Ensign
Posted: ‎2023-01-04 10:16 PM
In response to KarimBenameur
hi @KarimBenameur ,
I have attached the solution for your reference. We are not testing on any hardware but on the cloud VM using EVE setup by using Local Test simulation.
Also what is real time patch ?
Development_20230105-0449.sln.zip
