What's new in Data Center Expert
Data Center Expert release notes
Send InviteCancel
You can download the latest DCE device firmware update catalog that includes the IEC-certified NMC3 firmware 3.x from theEcoStruxure IT Entitlements portal.
An active support contract for all monitored nodes is required.
If you do not monitor NMC3 devices, you can download the DCE device firmware update catalog (SFSWCDFCF) that does not include IEC-certified NMC 3.x firmware here.
In this release:
ats5g hw21 3.4.0.2
Support for Multi-Factor Authentication added
New CLI Command to change the Display ID
SNMP Traps implemented for Open Fuse Alarms
su hw21 3.4.1.1
Miscellaneous security improvements
sucan hw21 2.5.5.1
UPS firmware update improvements (SRYL Devices)
Possible memory corruption during restart fixed
sucan hw21 3.4.1.1
sumx hw05 722
Creating a new user no longer requires reboot after mislatched password
sy hw05 722
When the DCE server is updated from version 8.3.0 to 9.0.0, all existing license keys will be removed and combined into one new DCE subscription license that enables the software for 90 days. Visit mySchneider Software Management within 90 days to update your license subscription.
In this release
eu1p hw21 3.2.0.5
Customized ini file name for integrity check
UPS fault alarm trigger corrected
External Battery Pack alarm text and translations updated
Login banner updated
su hw21 3.3.0.8
Command Line Interface (CLI) added to the Web UI
LDAP TLS fix for SAN type IPAddress
DHCPv6 stable through network interface reboot or cable reseat
sy hw21 3.3.0.8
LDAP TLS for SAN type IPAddress
rpdu hw21 2.5.2.5
Alarm status added to LCD Display
Web UI updated to clarify purchase process
Misc Cybersecurity Patches
su hw21 2.5.4.4
Email improvements for IPv6
sucan hw21 2.5.4.4
sucan hw21
CLI added to the Web UI
IPv6 functionality is improved
sy hw21 2.5.4.4
New DCE Device Firmware Catalog File
February 5, 2025
In this release
ats 5G 3.2.0.1
Screens added for frequency/voltage configuration and event counts
Communication over Modbus TCP protocol enabled
nb250 3.2.0.1
Firmware update of the wireless coordinator, routers, and sensors is now supported.
The Read-Only user can no longer access actions on the Device > Wireless sensor network page.
px 3.2.0.1
The Network-Only user permitted actions corrected in Web UI
Incoming BACnet packet sizes validated
Cooling fan outage alarm appears over SNMP
apc hw05 nb250 718
Character limit for the NetBotz Module Name increased
User can be modified via config file
Resolved SNMPv3 issue with monitoring
Go to apc.com for additional release note information.
Data Center Expert 8.3.0 released
January 2025
IMPORTANT: The update from 8.2.0 to 8.3.0 requires that you install a new certificate before you install the software update. See the instructions in the release notes.
