Creating a bootable USB Key (Windows or Linux machine) for DCE
Data Center Expert release notes
  • EcoStruxure IT Help Center
  • What's new in Data Center Expert
  • Data Center Expert release notes
  • Creating a bootable USB Key (Windows or Linux machine) for DCE
  • Mark as Read
  • Data Center Expert 9.0.0 release notes
  • Manage your DCE subscription license in mySchneide...
  • Data Center Expert subscription license FAQ
  • Data Center Expert 9.0.0 Virtual Machine trial sof...
  • Known issues in DCE
  • Data Center Expert 7.9.x and newer - server hardwa...
  • Creating a bootable USB Key (Windows or Linux mach...
  • Data Center Expert release summary
  • Data Center Expert 8.3.0 release notes
  • EcoStruxure IT Data Center Expert 8.2.0 release no...
  • EcoStruxure IT Data Center Expert 8.1.x Release No...
  • EcoStruxure IT Data Center Expert 8.0 release note...
  • Data Center Expert 7.9.3 release notes
  • Data Center Expert 7.9.2 release notes
  • Data Center Expert 7.9.1 release notes
  • Data Center Expert 7.9.0 release notes
  • Data Center Expert 7.8.1 release notes
  • Data Center Expert 7.8.0 release notes
  • Unplugged sensors in DCE 7.4.3
EcoStruxure IT Support
Request Support
Back to Data Center Expert release notes
  • Mark as Read
Picard EcoStruxureIT
‎2022-06-07 09:45 AM
Last Updated: Sisko JLehr Sisko ‎2024-08-23 05:52 AM
Instructions for a Windows machine:
  1. InsertUSBkey (no larger than 4GB) into your system.
  2. Extract the following file to a temporary directory:
    DCExpertUsbFlashRestore_Win_x.x.x_b.zip
  3. Open a command prompt and navigate to the temporary directory using the cd command.  The command prompt working directory must be the same location as the extracted files.
  4. Run mkDCExpertRestoreUsbKey.bat <iso image filename>.
    Example: mkDCExpertRestoreUsbKey.bat c:\tmp\restore.iso
  5. Answer the prompts as appropriate.
Instructions for a Linux machine:
  1. Insert a 2GB (or larger) USB key into your system.
    DCExpertUsbFlashRestore_Linux_x.x.x_b.tar.gz
  4. Run mkDCExpertRestoreUsbKey.sh <iso image filename>.
    Example: mkDCExpertRestoreUsbKey.sh /tmp/restore.iso
Third-party USB key scripts:
The scripts used to create USB keys use the following software:
Software
URL
Windows
Linux
Syslinux
http://syslinux.zytor.com/
X
X
7-zip
http://www.7-zip.org
X
GNU sed
http://unxutils.sourceforge.net
X
100% helpful (2/2)
