Sensor Service Methods
DCE web services API
  • EcoStruxure IT Help Center
  • DCE web services API
  • Sensor Service Methods
  • Mark as Read
  • EcoStruxure IT forum
EcoStruxure IT Support
Request Support
Back to DCE web services API
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
Sensor Service WSDL
A sensor represents any measurable value or state within a device or probe. It is easy to confuse the terms sensors and probes. In the Data Center Expert domain, a probe is a physical entity for measuring an aspect of the physical environment, while a sensor is a conceptual entity which simply references any device or probe value or state.
Sensors themselves have an associated state value. This value indicates whether the sensor is connected or not (for sensors associated with probes) and whether there is an alarm condition associated with the value of the sensor. Alarms are generally triggered when a sensor’s value exceeds a threshold defined by the user on the device or on Data Center Expert.
Sensors are organized by a pre-defined set of sensor types. Most devices support a DEVICE_STATUS sensor.
Some devices will support multiple instances of a particular sensor type such as the BREAKER_CURRENT sensor on a PDU. When a device does have multiple instances of a sensor, each instance will be identified by a sequential index number.
Some devices consist of modules or sub-systems and sometimes these modules have multiple instances of a certain type of sensor. In these cases, the sensor instances are double-indexed; once for the module instance and once for the sensor instance.
When referencing a NetBotz probe sensor, the sensor index often represents the port that the probe is plugged into.
The following methods are available through the Sensor web service.
initializeSensorService
This optional method serves two purposes. First, it allows the sensor web service to be customized using a string of parameter values (NYI). Secondly, it provides a mechanism for isolating the 2-3 second set up time required for the first (and only the first) invocation of the sensor service; otherwise, a client has to endure that set up time during the processing of that first sensor service request. Returns true if successful.
Service: ISXCentralSensorService
Parameter Type Description
initialParameters  String Ignored
getSensorByID
Returns an ISXCSensor object that represents a sensor being monitored by the Data Center Expert server and is identified by the specified ID.
ISXCElementID  String
The unique identifier of a sensor being monitored by the Data Center Expert server.
locale (optional) String
Specifies the locale results are translated into before being returned. The default value is the locale configured in the Data Center Expert server.
getSensorsByIDs
Returns a list of ISXCSensor objects that represent sensors being monitored by the Data Center Expert server and are identified by the specified IDs.
ISXCElementID list  String
A list of unique identifiers of sensors being monitored by the Data Center Expert server.
getSensorsByType
Returns a list of ISXCSensor objects that represent sensors being monitored by the Data Center Expert server and are of the specified type.
sensorType ISXCSensorType
The specific type of the sensors to return.
getSensorsForDevice
 Returns a list of ISXCSensor objects that represent sensors connected to the DCE-server-monitored device that is identified by the specified ID.
The unique ID of the device to return sensors for.
sensorType (optional) ISXCSensorType
The sensor type to filter the results on.
getDeviceForSensor
Returns an ISXCDevice object that represents the DCE-server-monitored device that the sensor with the specified ID is connected to.
The unique ID of the sensor to return the device for.
getSensorData
Returns an ISXCSensorData object that represents the current value data for the sensor with the specified ID.
The unique ID of the sensor to return the data for.
For the getMultiple<X> methods, it is important to realize that specifying large sensor ID lists or “wide” date ranges can cause excessive CPU and/or memory utilization resulting in overall performance degradation. To prevent this, specify as few sensors and/or as narrow a date range as is reasonable for your application.
getMultipleSensorData
Returns a list of ISXCSensorDataSet objects that represent the current value data for a list of sensors with the specified IDs. Recommended when querying for data for 4 or more sensors. For 3 or less sensors, it may be more efficient to use the getSensorData method.
The unique IDs of the sensors to return the data for.
getMultiplePeakSensorData
Returns a list of ISXCSensorDataSet objects that represent the peak value data for a list of sensors with the specified IDs. Recommended when querying for data for 4 or more sensors. For 3 or less sensors, it may be more efficient to use the getSensorDataRange method.
startDateTime (optional) xsd:datetime
The start date-time of the range to return data for, or null to return data from start of recorded data.
endDateTime (optional) xsd:datetime
The end date-time of the range to return data for, or null to return data until the end of recorded data.
getMultipleAverageSensorData
Returns a list of ISXCSensorDataSet objects that represent the average value data for a list of sensors with the specified IDs. Recommended when querying for data for 4 or more sensors. For 3 or less sensors, it may be more efficient to use the getAverageSensorData method.
getHistoricalSensorData
Returns a list of ISXCSensorData objects that represent the recorded value data for a sensor with the specified ID.
maxDataPoints (optional) integer
The max number of data points to return in the request. Value cannot exceed 1000.
Note: ISXCSensorData objects contain timestamps corresponding to when the sensor data was captured. Since these timestamps can be used to determine/enforce sample order, there is no guarantee of any order in the returned list of samples.
Returns an ISXCSensorData object that represents the average value of recorded data for a sensor with the specified ID.
getAverageSensorRange
Returns the ISXCSensorData objects that represent the highest and lowest values of recorded data for a sensor with the specified ID.
Note: Normally ISXCSensorData objects contain timestamps corresponding to when the sensor data was captured. In the case of min/max sensor data, the timestamps are set to the user-specified EndDateTime. Because each min/max value could appear multiple times within a given date range, it is not possible to ascribe a specific collection date to either of the two returned min/max values.
getSensorEnumerations
Returns a list of localized strings that correspond to possible values for a sensor that returns an enumeration index as its current data value and is identified by the specified ID.
The unique ID of the sensor to return the enumerations for.
Note: For sensors with enumerated value-types, the enumerated value definitions can vary from device model to device model. For example, an enumerated value of “0” for BATTERY_STATUS may mean “OK” on one UPS but may represent “Unknown” on another. Data Center Expert strives to normalize these values so they are consistent across devices. The number of supported devices makes this difficult to guarantee.
Verify sensor enumerations for all device models your application supports.
ISXCentralSensorService_v2_0_360039289353.wsdl
Didn't find what you are looking for? Ask our Experts
