Device Service Methods
DCE web services API
  • EcoStruxure IT Help Center
  • DCE web services API
  • Device Service Methods
  • Mark as Read
  • Sensor Service Methods
  • Device Groups Service Methods
  • Data Center Expert Web Services API
  • Alarms Service Methods
EcoStruxure IT Support
Request Support
Back to DCE web services API
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
Device Service SDL
The Data Center Expert Device web service exposes information about devices being monitored by a Data Center Expert server, and some device control functionality. Third-party applications can also access this monitored device data.  Device control is supplied for select devices.
Once an application has obtained device data through the Devices web service, it can use other Data Center Expert web services to get alarm, device group, and sensor information about the devices.
The following methods are available through the Device web service. These methods only return information about devices the caller has permission to access.
getAllDevices
Returns a list of ISXCDevice objects that represent devices being monitored by the Data Center Expert server.
Service: ISXCentralDeviceService
Parameter Type Description
locale (optional) String The unique identifier of a device being monitored by the Data Center Expert server.
getDeviceByID
Returns an ISXCDevice object that represents a device being monitored by the Data Center Expert server, identified by the specified ID.
ISXCElementID String The unique identifier of a device being monitored by the Data Center Expert server.
Specifies the locale results are translated into before being returned. The default value is the locale configured in the Data Center Expert.
getDeviceByIPAddress
Returns an ISXCDevice object that represents a device being monitored by the Data Center Expert server, identified by the specified IP address.
ipAddress String
The IP address of a device being monitored by the Data Center Expert server.
getDeviceByHostName
Returns an ISXCDevice object that represents a device being monitored by the Data Center Expert server, identified by the specified host name.
hostName String
The host name of a device being monitored by the Data Center Expert server.
getDevicesByType
Returns a list of ISXCDevice objects that represent devices being monitored by the Data Center Expert server and are of the specified device type.
deviceType ISXCDeviceType
One of the valid device type identifiers for devices that can be monitored by the Data Center Expert server.
getDevicesBySerialNumber
Returns a list of ISXCDevice objects that represent devices being monitored by the Data Center Expert server and have the specified serial number.
serialNumber String
The serial number of one of the devices being monitored by the Data Center Expert server.
For NetBotz devices, the “virtual” parent device inherits the serial number of the child enclosure device, hence the need to return a list of devices.
getDevicesByModelNumber
Returns a list of ISXCDevice objects that represent devices being monitored by the Data Center Expert server and have the specified model number.This method is currently not functional, so will return no devices.
modelNumber String
The model number of one or more of the devices being monitored by the Data Center Expert server.
getDevicesByModelName
Returns a list of ISXCDevice objects that represent devices being monitored by the Data Center Expert server and have the specified model name.
modelName String
The model name of one or more of the devices being monitored by the Data Center Expert server.
getChildDevices
Returns a list of ISXCDevice objects that represent any devices being managed by the device with the specified ID.
getParentDevice
Returns an ISXCDevice object that represents a device managing the device with the specified ID.
getDeviceControlTypes
Returns a list of ISXCDeviceControlType objects that represent a grouping of a particular type of device control (example: Outlet Control).
getControllableDevicesByControlType
Returns a list of ISXCDevice objects that represent devices being monitored by the Data Center Expert server and have controls of the specified type.
controlTypeID String
Specifies the control type ID used to identify a control type.
getDeviceControlsForDevice
Returns a list of ISXCDeviceControl objects representing the device controls, of the specified type, supplied by this device.
ISXCElementIDForDevice String
Specifies the unique identifier of a device being monitored by the Data Center Expert server.
setDeviceControlByID
Set the value of a device control. Note: This method does not supply a response.
ISXCentralDeviceService_v2_0_360039288053.wsdl
Comments
Jym
Jym
Cadet
  • Mark as Read
‎2024-02-27 01:14 AM
Hello, I tried to get the information
Application version and Mac address of a device but i can't find it in the API. Is the info available or not?
