Alarms Service Methods
DCE web services API
  • EcoStruxure IT Help Center
  • DCE web services API
  • Alarms Service Methods
  • Mark as Read
  • Sensor Service Methods
  • Device Service Methods
  • Device Groups Service Methods
  • Data Center Expert Web Services API
EcoStruxure IT Support
Request Support
Back to DCE web services API
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:13 AM
Alarms Service WSDL
Alarms are conditions within the data center infrastructure that require attention. The textual contents of Data Center Expert alarms are localized to a user specified locale when they are retrieved from the server. If no locale is specified, the server default locale is assumed.
All alarms contain a reference to the device that is experiencing the alarm condition. If an alarm is associated with a specific device sensor, a reference to that sensor may also be included in the alarm. Sensor-related alarms are usually generated when a user-defined threshold for the sensor value is violated. Sensor thresholds can be defined either directly on the device or in the Data Center Expert server.
An alarm is either active, meaning the condition that triggered the alarm still exists, or resolved, meaning the trigger condition no longer exists.
The following sections describe the methods of the Alarms service.
getAllActiveAlarms
Returns a list of ISXCAlarm objects that represent all alarms that are currently unresolved in the Data Center Expert server.
Service: ISXCentralAlarmsService
Parameter Type Description
locale (optional) String
Specifies the locale results are translated into before being returned. The default value is the locale configured in the Data Center Expert server.
getAlarmByID
Returns an ISXCAlarm object that represents an alarm (active or resolved) in the Data Center Expert server and is identified by the specified ID.
ISXCElementID String
The unique identifier of an alarm that was created in the Data Center Expert server.
getActiveAlarmsForDevice
Returns a list of ISXCAlarm objects that represent active alarms associated with an DCE-server-monitored device which is identified by the specified ID.
The unique identifier of a device that is being monitored by the Data Center Expert server.
excludeSensors (optional) boolean
When set to true, alarms associated with sensors will be filtered from the result set, and only alarms that are directly associated with the device will be returned.
getActiveAlarmsForSensor
Returns a list of ISXCAlarm objects that represent active alarms associated with an DCE-server-monitored sensor which is identified by the specified ID.
The unique identifier of a sensor that is being monitored by the Data Center Expert server.
getActiveAlarmsForSeverity
Returns a list of ISXCAlarm objects that represent active alarms which have a severity that matches the specified severity level.
severity ISXCAlarmSeverity
The severity to filter the resulting alarms on.
getAlarmsHistory
Returns a list of ISXCAlarm objects that represent alarms that were active during the specified time frame.
startDate xsd:datetime
The start date-time of the range to return data for.
endDate xsd:datetime
The end date-time of the range to return data for.
getAlarmsHistoryForDevice
Returns a list of ISXCAlarm objects that represent alarms that were active during the specified time frame and associated with the specific device.
The unique identifier for an DCE-server-monitored device.
When set to true, alarms associated with sensors are excluded from the results, and only alarms directly associated with the specified device are returned.
getAlarmsHistoryForSensnor
Returns a list of ISXCAlarm objects that represent alarms that were active during the specified time frame and associated with the specific sensor.
The unique identifier for an DCE-server-monitored sensor.
getAlarmsHistoryForSeverity
Returns a list of ISXCAlarm objects that represent alarms that were active during the specified time frame and were of the specified severity.
The alarm severity to filter the results on.
getAlarmsDeltaHistory
Returns a list of ISXCAlarm objects that represent alarms that had a change of status during the specified time frame.
secondsInPast integer
The number of seconds to go back (relative to “now”) and evaluate alarm data for.
getAlarmsDeltaHistoryForDevice
Returns a list of ISXCAlarm objects that represent alarms that had a change of status during the specified time frame and were associated with the specified device.
getAlarmsDeltaHistoryForSensor
Returns a list of ISXCAlarm objects that represent alarms that had a change of status during the specified time frame and were associated with the specified sensor.
getAlarmsDeltaHistoryForSeverity
Returns a list of ISXCAlarm objects that represent alarms that had a change of status during the specified time frame and were of the specified severity.
setAcknowledgmentForAlarm
Allows the user to comment an alarm, set the alarm as hidden, and to suppress notifications of this alarm.
alarmID String
The unique identifier for an alarm.
comment (optional) String
The comment the user wants to add to the alarm acknowledgment history.
 isAlarmHidden  boolean
Indicates if the alarm should be hidden in the DCE clients.
 isAlarmAlertSuppressed boolean
Indicates if the alarm notifications (alerts) should be suppressed.
getAcknowledgmentForAlarm
Allows the user retrieve the acknowledgments status: is alarm hidden, are alarm notifications suppressed.
alarmID String
getAcknowledgmentHistoryForAlarm
Allows the user to retrieve the acknowledgment history for an alarm.
alarmID String
deleteAcknowledgmentByID
Allows the user to delete alarm acknowledgment comments.
 acknowledgmentID int
The unique identifier for an alarm acknowledgment.
alarmID String
ISXCentralAlarmsService_v2_0_360039287493.wsdl
