Managing the export action configurations
DCE reports
  • EcoStruxure IT Help Center
  • DCE reports
  • DCE reports
  • Managing the export action configurations
  • Mark as Read
  • Saved Sensor Reports section
  • Reports feature
  • Differences between a summary-format report and a ...
  • Reports feature
EcoStruxure IT Support
Request Support
Back to DCE reports
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
You can add new export action configurations, or edit existing configurations, using the "Export Action Configuration" display, accessed from the Manage Export Scheduling option of the Reports menu.
Note
To remove an export action configuration, select it in the list and click Remove Export.
Adding a new export action configuration
  1. Select Export Action Configuration, accessed from the Manage Export Scheduling option in the Reports menu. Alternatively, click the Edit Report Scheduling option in the Saved Sensor Reports section of the Reports perspective, or click the Edit Report Criteria icon in a graph-format report, to access the Name and Schedule Data Export option.
  2. In the "Export Action Configuration" display, click Add Export to access the "Add Export" wizard. Alternatively, in the "Name and Schedule Data Export" display, click Add Export to access the "Add Export" wizard.
  3. In the "Choose Export Type" display, select the type of export action configuration you want to add.
  4. In the settings display for the selected export type, define the settings.
    Note
    Each export type uses its own settings display to add or edit an export configuration.
  5. Click Test Export to test the export settings.
    Note
    You need to verify the test was successful. For example, for e-mail settings, verify an e-mail was received.
Editing an export action configuration
  2. In the "Export Action Configuration" display, select a listed export, and click Edit Export.
  3. In the settings display for the selected export configuration, define the settings.
    Note
    Each export type uses the its own settings display to add or edit an export configuration.
  4. Click Test Export to test the edited export settings.
    Note
    You need to verify the test was successful. For example, for e-mail settings, verify the e-mail was received.
