Differences between a summary-format report and a table-format report
DCE reports
Send InviteCancel
A summary-format report shares all of the same features as a table-format report, with the following exceptions:
A table-format report provides entries for each value change at those sensors during the reports time-frame; a summary-format report provides a single entry for each selected sensor that summarizes the values at those sensors during the reports time-frame.
Unlike a table-format report, a summary-format report does not include a Status column.
Note: A summary-format report includes information about the Last Known Value, which has a different meaning than the Value reported by a table-format report.
Only a summary report includes the following information:
Column
Description
Minimum Value
The lowest value recorded during the time-frame of the report.
Maximum Value
The highest value recorded during the time-frame of the report.
Average Value
The average of the values recorded during the time-frame of the report.
Last Known Value
The most recent value recorded before the end of the time-frame of the report.
Delta Value
The difference between the minimum and maximum values recorded during the time-frame of the report.
Total for Delta Value
The total of the delta values for the sensors in the report, included when Show Total for Delta Value is selected in the "Edit Report Options" display.
Note: The Show Total for Delta Value option is available only when all sensors in the report are the same type.
