State alarm thresholds
DCE alarm thresholds
  • EcoStruxure IT Help Center
  • DCE alarm configuration
  • DCE alarm thresholds
  • State alarm thresholds
  • Mark as Read
  • Thresholds and supported devices
  • Other state thresholds
  • Other numeric thresholds
  • Numeric alarm thresholds
  • Creating numeric and state thresholds
  • Create Thresholds option
EcoStruxure IT Support
Request Support
Back to DCE alarm thresholds
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:15 AM
State thresholds are thresholds defined for sensors that report state values.
There are three specific types of state thresholds that can be set for state sensors.
State threshold options
Value: Open or Closed Unknown, No Fault, or Fault No Motion or Motion Detected Varied
Threshold Description
Door Settings for sensors that determine whether a door is open or closed.
Dry Contact Settings for sensors that determine the fault status of dry contacts.
Motion Sensor Settings for sensors that detect motion.
Other State Sensors Settings for sensors that measure state settings not reported for other Thresholds options.
State threshold types
Setting Description
State Threshold An alarm occurs when the sensor state matches the Alarm State setting.
State Mismatch Threshold An alarm occurs when the sensor state does not match the Normal State setting.
Note
This threshold setting is useful for sensors that can report more than two states.
State for Time Threshold An alarm occurs when the sensor state matches the Alarm State setting for longer than the delay in the Time Allowed in Alarm State setting.
State Mismatch for Time Threshold An alarm occurs when the sensor state does not match the Normal State setting for longer than the time defined by the Time Allowed in Alarm State setting.
Note
