Other state thresholds
DCE alarm thresholds
  • EcoStruxure IT Help Center
  • DCE alarm configuration
  • DCE alarm thresholds
  • Other state thresholds
  • Mark as Read
  • Thresholds and supported devices
  • State alarm thresholds
  • Other numeric thresholds
  • Numeric alarm thresholds
  • Creating numeric and state thresholds
  • Create Thresholds option
EcoStruxure IT Support
Request Support
Back to DCE alarm thresholds
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
The Other State Sensors option allows you to set thresholds for state sensors that monitor operational states not covered by the three threshold-specific, state options.
The following lists identify some common examples of state sensors you can configure using the Other State Sensors option. The actual sensors will depend on the device types managed by the Data Center Expert server. These options use the same set of four threshold settings as the other state threshold options.
Note
You can configure multiple sensors discovered for the Other State Sensors option, when the sensors you select use the same alarm states settings. For example, all sensors that use On and Off states can be configured at the same time, as can all sensors that use Up and Down.
Active/Inactive:
  • Button
  • Temperature Override Status
Open/Closed:
  • Input Contact
  • Output Relay
  • Bypass
On/Off:
  • Switch
  • Outlet
  • Alarm Device
  • Test Relay
Other Settings:
  • Ethernet Link
  • UPS Input Voltage (line neutral)
  • Current Output Phase
Fault/No Fault:
  • Contact
  • Input State
Connected/Disconnected:
  • Speakers
  • External Microphone
Yes/No:
  • UPS on Bypass
  • UPS on Battery
  • Audio Alarm
  • Battery Low
  • Overload
  • Inverter Off
  • UPS Over Temperature
  • Utility Power Failure
  • Battery Needs Replacement
  • Battery Fault
Multiple Statuses::
  • Online
  • Device Status
  • Battery Status
  • UPS Status
  • Communication Status
  • Alarm State
  • Self-Test
  • Runtime Calibration
  • Reason for Last Transfer to Battery
  • Battery Charge Fault
  • Rack ARU Operating Status of Fan
  • ARU Primary Power Present
