Device Label Settings display
DCE Device and Map views
  • EcoStruxure IT Help Center
  • DCE Device and Map views
  • Device Label Settings display
  • Mark as Read
  • Outlet control display
  • Device and Map Views
  • Custom Properties Editor view
EcoStruxure IT Support
Request Support
Back to DCE Device and Map views
  • Mark as Read
Sisko JLehr Sisko
‎2024-02-14 09:41 AM
Define a custom label to display in the Device View's Label column for the selected SNMP or Modbus device. Otherwise, the default device label is displayed.
Element Description
Use default device label Checked by default. Clear the check mark to specify a custom device label.
Custom device label Modify the label for the selected SNMP or Modbus device.
Comments
jlales
jlales Cadet
Cadet
  • Mark as Read
‎2024-02-22 01:21 PM
Can I rename Modbus device names in DCE so alarms are specific to the device and not just "x.x.x.x Modbus ID x"
