Manage Custom Property Keys display
Custom properties
Send InviteCancel
This display allows you to manage custom property keys only. To identify the value associated with a custom property key, you use the Add Custom Property display, accessed from the right-click menu of the Device View, Map View, or Custom Properties Editor view.
You can choose to display a new custom property key as a column in the Device View, or select it later in the Configure Columns display.
