Adding a Custom Property
Custom properties
  • EcoStruxure IT Help Center
  • DCE configuration
  • Custom properties
  • Adding a Custom Property
  • Mark as Read
  • Manage Custom Property Keys display
EcoStruxure IT Support
Request Support
Back to Custom properties
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:13 AM
You can add a new custom property, or modify the value of an existing custom property, for the selected devices.
  1. In the Device View, Map View, or Custom Property Editor view, right-click one or more devices or sensors.
  2. Select Add Custom Property.
  3. In the Property Key field, enter a name for a new custom property.
  4. In the Value field, enter the value you want for the new property, or select an existing property key to modify its value.
  5. Click OK.
  6. In the Add Column to Device View display, choose whether to add the new property key as a viewable column in the Device View and Device Sensor displays by selecting Yes or No.
    You can use the Configure Columns icon to show or hide columns at a later time.
