Image Settings
Camera settings
  • EcoStruxure IT Help Center
  • Monitoring NetBotz Appliances in DCE
  • Camera settings
  • Image Settings
  • Mark as Read
  • Select Camera display
  • Masking
  • Image Settings
  • Alarm Capture Data
  • Masking
  • Image Settings
EcoStruxure IT Support
Request Support
Back to Camera settings
  • Mark as Read
Image Settings
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
Image Settings
Use this option to configure the image quality and other settings (such as Timestamp Location) used for the selected camera during alarm and surveillance activities.
Element Description
Brightness (0-255) Sets the brightness of the captured image. The value can be set from 0 to 255.
Gamma Correction Use this control to adjust the overall brightness of the camera image. Gamma Correction enables you to display captured image more accurately on your computer screen. Images which are not properly corrected can look bleached out or too dark.
Rotate Camera Image 180 Degrees Select to rotate the image captured by the camera 180 degrees. This is useful for correctly orienting the image captures included in alert notifications and in the NetBotz Advanced View when the device has been mounted upside down due to installation location restrictions.
Note
This option is not available for use when configuring Capture Settings for CCTV Adapter Pods.
Type of Lighting
Use this control to specify the color balance settings that will be used by the camera. The four pre-configured color balance selections are:
Fluorescent: best color balance settings for locations with fluorescent lighting.
Incandescent: best color balance settings for locations with incandescent lighting.
Daylight: best color balance settings for locations with natural lighting.
Auto-detect: analyzes the current lighting conditions and automatically selects the best.
Custom: use the Red balance and Blue balance controls to fine tune the image to your specifications.
Red Balance (1 - 254) Adjusts the color balance of the image to counteract the effect of the lighting in the clip.
Blue Balance (1 - 254) Adjusts the color balance of the image to counteract the effect of the lighting in the clip.
Timestamp Location
Use this control to specify the location of the timestamp within the image capture: None, Bottom right, Bottom center, Bottom left, Top right, Top center, and Top left.
