CAD Import supported entities
Building the ITA infrastructure
  • EcoStruxure IT Help Center
  • IT Advisor
  • Building the ITA infrastructure
  • CAD Import supported entities
  • Mark as Read
  • Building the infrastructure and adding inventory
  • Adding rack-mountable equipment to the room layout
  • Adding multiple pieces of equipment with bundles
EcoStruxure IT Support
Request Support
Back to Building the ITA infrastructure
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-06 07:12 AM
When importing from a CAD drawing (.dwg file), these entities are supported and recognized by IT Advisor.
The DWG drawing must have measurement units (e.g. mm or inches) specified to allow import at the correct scale.
To detect a room or a cage, the lines must be closed, meaning shapes containing open doors or windows are not detected. The room must be drawn using poly-lines to be able to use the detect wall tool.
Shapes
Arc
Circle
Line
MText
Polyline
Text
Hatch (only filled with a solid color)  check_360037994574.pngcheck_360037994574.png
