Workstation Pro License at v1, site is now v2 or v3, so WorkStation will not run after upgrade
  • Workstation Pro License at v1, site is now v2 or v3, so WorkStation will not run after upgrade
  • DavidChild
    DavidChild
  • Dave_Shore
    Dave_Shore
Dave_Shore Schneider Alumni (Retired)
‎2018-10-03 02:38 AM
Last Updated: Sisko DavidChild Sisko ‎2019-11-06 06:50 AM
Workstation Pro License fails to allow running of v2.0 or v3.x EcoStruxure WorkStation following an upgrade
  • WorkStation
  • Licensing
Workstation Pro License SXWSWWORK00002 (SW-STATION-PRO-0) is the same for v1.x and v2.x, so that WorkStation Pro should continue to operate after an upgrade.
However, there was a License upgrade/change at v1.7 (from v1 to v2) and if the License was registered before this the version remains at v1 and this will not run v2.x WorkStation
The WorkStation Pro License needs to be returned, then re-installed using the online Licensing system.
 Before License is returnedBefore License is returned
 After license is returnedAfter license is returned
 The process to return a license can be found in Webhelp.
  • DavidShore19
100% helpful (4/4)
