What range of engineering ports does PCT (Project configuration tool) use
  • What range of engineering ports does PCT (Project configuration tool) use
  • DavidChild
    DavidChild
  • Gary
    Gary
Gary Schneider Alumni (Retired)
‎2022-02-02 06:07 AM
Last Updated: Sisko DavidChild Sisko ‎2022-02-02 06:09 AM
The port range used by the Project Configuration Tool is incorrectly documented.
Documentation and web-help states the port range is 49152 to 65535, this is incorrect.
The correct port range used, for the engineering ports, i.e. the ports that the EBO servers are listening too, so that it is possible to log on with WorkStation is 32768-61000.
Labels (2)
  • Project Configuration Tool
  • GaryMontague22
100% helpful (1/1)
