Watchdog Operated Trouble
Select a Country
  • Watchdog Operated Trouble
Sandeep_Kumar006 Troubleshooter
‎2025-08-03 10:17 PM
Last Updated: ContentModerator Explorer ‎2025-09-01 03:28 AM
The panel displays a Process Watchdog Operated condition. This is accompanied by General Trouble.
ESMI Fire Detection.
  • FFSULH1001.
  • FFSULH1002.
  • FFSULH1003.
Warning
Electrostatic Discharge Required: Always discharge static electricity from your person by touching metal prior to handling any hardware. Failure to do so may result in damage to devices.
The system has reported a watchdog trouble due to a malfunction in the main processor unit located on the LCD backboard. During this condition, the Watchdog LED will illuminate.
  1. Locate the LCD backboard: On the back side of the LCD board, find the reset switch (red-circled area in the reference photo).
  2. Reset the watchdog condition: Press and release the reset switch to reset the watchdog condition.
  3. Observe system behavior:
    • If the system recovers to normal operation, no further action is needed.
    • If the watchdog trouble persists, proceed to replace the LCD main processor board.
  • ESMI Fire Detection
  • SandeepKumar25
