Using WorkStaion 3.2.2.61 with PCT, error 'Server version not compatible with client' is displayed
  • Using WorkStaion 3.2.2.61 with PCT, error 'Server version not compatible with client' is displayed
  • DavidChild
    DavidChild
  • Gary
    Gary
Gary Schneider Alumni (Retired)
‎2021-05-05 04:23 AM
Last Updated: Sisko DavidChild Sisko ‎2021-05-05 04:23 AM
PCT workstation displays message “Server version not compatible with client", when restoring a server configuration with new IDs.
Buildings Operation Project Configuration Tool
When backing up and restoring an AS-P/AS-B with a new ID in PCT at EBO 3.2.2.61, when logging back on with PCT using the installed EBO workstation,  the message “Server version not compatible with client" is displayed
PCT is the offline programming tool but, it launches the workstation installed on the computer.
If the workstation version on the computer is EBO 3.2.2.61, Hotfix 3.2.2.4002 (CP3) is required to be installed on the computer running PCT, taking the computer’s installed workstation version to 3.2.2.4002.
Labels (2)
  • Project Configuration Tool
  • GaryMontague21
34% helpful (1/3)
